» Happy Anzac Day!by Boats13 Today at 11:03 pm
by sosam117 Today at 10:41 pm
» Fox .35 Modifications
by Ken Cook Today at 10:20 pm
by MauricioB Today at 4:08 pm
by rsv1cox Today at 3:56 pm
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
Postage stamp backplate mount?
Re: Postage stamp backplate mount?
Yep, looks exactly like the one I have. Works well.
mr_cox wrote:How do you use it?
you know that postage stamp backplates do not have screw mounts?
Yeah this uses crankcase crews to add a set of mounts to the engine.
Lots of good stuff on the german bay, not many of them accept paypal though...
Yeah a lot of great stuff.
When I want translation I just call on our resident German speaker
GermanBeez
GermanBeez
yes, do so lol
GermanBeez- Platinum Member
mine
I`m going to make mine out of aluminum for weight savings,I like the postage stamp backplates.
Jaspur_x- Banned
I guess because they are less common and are compact compared to some others........and can be throttled with my mount ,experiments forthcoming
But my other mounts will be even nicer
Jaspur_x- Banned
Jaspur_x wrote:I guess because they are less common and are compact compared to some others........and can be throttled with my mount ,experiments forthcoming
Cool and I suppose yeah they can fit in smaller airframes.
Postage Stamp Motor Mount
Didn't Goldberg make an aftermarket Postage Stamp motor mount? Does anyone have any type Postage Stamp mount that they would like to part with? I have two PS Backplates that I have been wanting to do some experimenting with concerning drilling intake opening for enhanced performance. for the New Year!!!
astronomer1- Moderate Poster
The Ebay postage stamp motor mount shown, is I believe a Graupner product. I think the Goldberg aftermarket mount was made of sheetmetal and was probably stronger. The linked German listing is not available in the U.S. Have never seen a real cox one.
If I can't get a hold of a real mount after market or not, I may fabricate one out of .o20" alum.
Big Al- Gold Member
Imho, the best feature is the 128 thread per inch needle assembly.nitroairplane wrote:What is it your like about them?
Head and shoulders above the standard one.
The Goldberg postage stamp mount came packaged with a balloon
bladder tank, 2 short pieces of fuel tube and a rubber band.
Good way to utilize an engine after the plastic plane
has crashed for the last time.
Bolt/screw hole pattern is the same as the reedie backplates, but horizontal-sideways.
Big Al's picture(above post) shows this better.
dckrsn- Diamond Member
Jaspur_x wrote:I`m going to make mine out of aluminum for weight savings,I like the postage stamp backplates.
Jaspur, did you ever make one?
It's been a while since anyone's mentioned running a postage stamp back-plate.. and I know that there's a lot of us who have at least one kicking around in a box somewhere. I noticed tonight that Cox International stocks "what I think" are the necessary parts to assemble a complete postage-stamp "back-end".
The back-plate w/spray-bar..
The fine-thread needle..
and an overhaul-kit with the necessary shorter 2-56 crankcase screws..
This arrangement wasn't very popular after the production-model it was designed for was broken.. because it could not be mounted in a conventional way, in another model. The Cox Babe Bee reed-valve engine was readily available separately.. with integral tank and easy firewall mounting.. and these 190 product engines were either discarded.. or used for spare-parts. Sad... because they had a fine-thread needle, which offered much finer tuning and is essential for using a pressure-bladder. You can still find aftermarket mounts on ebay though. Carl Goldberg made them years ago.. as well as other firms.
I made my own 2-piece sheet-aluminum mounts on a CNC machine about a year ago.. and still have some. Eric (Getback) tried a set.. but experienced a stress-fracture on a bend-point on one of the mounts after a few flights. It may have been an isolated incident. I mailed out a few sets to others.. but didn't get any feedback.
This is my experiment with the postage stamp type mount. it is machined from 1 inch aluminum square tubing. The bolt pattern for the mount is the same as the tanked Bees. After all this I found that I have about half a dozen or more of the white and some red horseshoe backplates with the fine thread needle. So using this mount is moot unless it is used on a plane that has a tanked Bee bolt pattern on the firewall. I might try it with a bladder set up.
'addict
'addict
coxaddict- Gold Member
I think your mount is nicely configured. I tried bending up a two part mount using 6061 T-6 and while it did work, it cracked on the radius. Seeing that your tubing is extruded, I don't feel that would be an issue. Very cool. Ken
Oh yes that's a cool mount, addict!
I was thinking of using pieces of aluminum bar that I'd drill and mill (I wish) or file in such a profile that they would fit to the backplate and extend above or to the sides of the backplate and the extending parts would have the mounting bolt holes. Kinda like the ones Roddie made but from a solid billet instead of bending to avoid the stress fractures. Never got enough round-toits gathered to do that.
I like your solution, very well thought of
Thanks guys,
After all the planning and work, I found that I don't need the mounts at this time. If any one wants one, PM me. I have 2 to send away.
Cheers
Cheers
These mounts also act as a girdle to help seal the plastic backplate, which is prone to warping and leaking in air.
» Cox Postage Stamp Engine Mount
» Postage stamp mount rebirth
» Respect the red postage stamp backplate reedie!
