» Happy Anzac Day!by Admin Today at 5:50 pm
» Fox .35 Modifications
by Onelife Today at 4:34 pm
by MauricioB Today at 4:08 pm
by rsv1cox Today at 3:56 pm
by rsv1cox Today at 7:17 am
by getback Today at 6:20 am
Pee Wee .020 diesel crank
Does anyone have a picture of a Pee Wee .020 heavy duty diesel crank? I think Davis may have made one.
jsesere- Rest In Peace
Re: Pee Wee .020 diesel crank
I don't think there ever was one for the pee wee engine. The stock crank has held up fine for me, but you have made sure that you have a good sealing head where you can release the compression setting enough. The DDD one with their teflon disks are very dangerous here. Mine was to high on the compression setting, plus the Teflon would never seal well enough. The solution is to grind off a bit from the counter piston in lathe, and to make a disc from sheet metal instead. Brass has worked well for me there.
I contacted Davis and he made one at one time, but he didn't have any pictures.
Thanks for the info.
Joe
Joe
Here is a short video of mine after the fix, spins a graupner 6x3 prop at around 9500rpm, and pulls a J3 cub around with authority.
https://www.youtube.com/watch?v=mMJlI0rgXVo
» Wanted: Tee Dee .049 crank case and crank
» Introducing the Blue Bee, the Blew diesel Medallion, and the disappointing OK Cub diesel.
» My crank said No!
» 049 crank vs. 051 crank
» Diesel Fuel Question
» My crank said No!
