» Revivng Some Childhood Classicsby rsv1cox Today at 7:17 am
by getback Today at 6:20 am
by getback Today at 6:17 am
» Fox .35 Modifications
by Onelife Yesterday at 4:36 pm
» TD/Medallion .049 fuel draw issues
by Ken Cook Wed Apr 24, 2024 7:18 pm
Taifun and wierd cox style backplate revisited
I assembled the "parts" Taifun "Hurrican" and discovered that the screened screw on venturi cap is missing, not much on the net regarding this engine. Anyone have a parts source?
And, any idea's as to what the back plate came from, a Cox model perhaps? It's strange because the intake opening is 90 degrees off from the vent/filler tubes.
Re: Taifun and wierd cox style backplate revisited
That backplate is for your Aurora.
IIRC, the bolt holes are very close but not exact. I think it does fit with a little bit of finagling.
I'm fairly sure the bolt holes are correct, but the spigot of the tank (reed holder) is a little smaller on a Cox tank and you'll need a small spacer ring (so I'm led to believe). Maybe it's the other way around and you need to turn the Cox tank down???
https://www.coxengineforum.com/t8797-cox-aurora-is-this-a-new-cox-engine
I know there is someone out there who hot-rods the Tornado engines & fits Cox tanks etc. Can't seem to find him at the moment. Builds custom tether cars as well. Sure someone will know who I mean.
Oldenginerod wrote:I'm fairly sure the bolt holes are correct, but the spigot of the tank (reed holder) is a little smaller on a Cox tank and you'll need a small spacer ring (so I'm led to believe). Maybe it's the other way around and you need to turn the Cox tank down???
Thanks for that look-back Rod. I did quickly marry the Cox tank to the Aurora engine and it seemed a proper fit. I think I will try a FrankenCoxAurora set-up and see what I get.
rsv1cox wrote:Oldenginerod wrote:I'm fairly sure the bolt holes are correct, but the spigot of the tank (reed holder) is a little smaller on a Cox tank and you'll need a small spacer ring (so I'm led to believe). Maybe it's the other way around and you need to turn the Cox tank down???
It may be a good idea to measure the depth as well so that the rod is securely retained on the crank pin but there is adequate clearance. By the way, if you need a Tornado head, MECOA have them.
» metal tank mount for the 049 td suggstion/ request
» Taifun Blizzard, Taifun Orkan
» Wierd enough to be Franken?
» Little Traveler revisited
» Boiling a Taifun
» Boiling a Taifun
