» Here we go again... another Lawn-Boyby roddie Today at 7:36 pm
by F4D Phantom II Today at 7:33 pm
by Kim Today at 6:53 pm
» Help Pee Wee tank cap .020
by MauricioB Today at 6:45 pm
by GTO455 Today at 6:11 am
by rsv1cox Today at 5:29 am
» Post your Older books
by rsv1cox Yesterday at 5:51 pm
by rsv1cox Yesterday at 4:58 pm
» I brake for Turtles....
by rsv1cox Yesterday at 4:38 pm
» Ball - Socket Joints
by Ken Cook Yesterday at 1:06 pm
» A little nostalgia…
by MauricioB Yesterday at 12:32 pm
by davidll1984 Yesterday at 8:32 am
Cox Conquest .15
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: Cox Conquest .15
Man....throw that thing in the saddlebag of that blue two-wheeler of yours and bring it down to the Skunk Works ! We'll run it, and video it! I got Thursday evening open !
You don't need any electric starters, the conquests are really user friendly engines, just prime until a little wet, set the throttle near idle and flip, should fire right up. Deburr the prop or use a glove.
If it doesn't start then something is wrong. Prime it a little wet and it will start if you have a good glowdriver. The handheld ones are not very good, the batteries have to be absolutely fully charged to be anywhere near the required voltage of 1.5V. The average battery voltage of 1.2V is not enough for a little wet engine...
Surfer_kris wrote:the conquests are really user friendly engines
Easy for you to say
You'll also need full castor fuel, the synthetic stuff is no good on old-school engines...
All I can tell you is my arm is sore,my finger hit the needle valve more then once and ripped my finger open.
Oh and fuel BURNS in a cut!!!!
Yes I see the air bubble, that's from sitting overnight.
I think I need a better glow plug clip, then the stock Cox clip.
WingingIt74 wrote:I think I need a better glow plug clip, then the stock Cox clip.
When in doubt, alligator clips.
Any chance you wound up with a 2.0v glowplug? Used to make those, for wet cell batteries. Course that was back in the day, might be hard to find one nowadays, even if you were looking.
ahrma_581- Gold Member
The battery tray and clip from Bernie works well:
Surfer_kris wrote:The battery tray and clip from Bernie works well:
I'll post a pic what I made. I can switch it from 1.5V to 3V. 2 D cells don't last really long when trying to get an engine to run though.
2 D cells should last a few months, depending on how much you fly, you can also use rechargable batteries if you prefer. The trick is to not have the battery connected all time. Prime and turn the engine over until it feels right first, and only then do you connect the battery, it should fire right up or something is wrong.
Ya you said that. BUT how do I know what "feels right"? I tried to get it to fire on prime only and no go, so I think my batteries were shot or my connection was bad.
It feels a bit wet but not sloppy and the compression feels a bit more because feel is tanking up space in the combustion chamber.WingingIt74 wrote:Ya you said that. BUT how do I know what "feels right"? I tried to get it to fire on prime only and no go, so I think my batteries were shot or my connection was bad.
It was just getting sloppy. Not sure what's up. Directions say 5 turns, but to me that seems to much, but I couldn't get it to run on 3.5 turns either.
You'll need a good battery and connection to start an engine, sounds like a combination of too much fuel and not enough power to the glow plug.
Is your glow plug the correct length?
fit90- Diamond Member
as per MECOA, yes.
Long reach is a good match to the thread length in the head, but it should run on any glow plug length anyway.
Jason_WI- Top Poster
I think your exhaust manifold is upside down. Per the head and no spinner, it was a RC version converted. MECOA has most of those parts for this engine available I believe.
http://www.mecoa.com/rjl/c15/c15-parts.htm
https://shop.mecoa.com/shopdisplayproducts.asp?id=105
I wonder what the serial number means. Yours is 1002043 and mine is 2000203. Can there be that many out there?
per wikipedia:
Cox Conquest .15 (Cat# 2800 Manufactured 1976-1978)
I would guess yours is a 1976 and mine is a 1977.
I think the cylinder and piston are shot. It won't hold compression and it hisses past into the exhaust.
» Cox Conquest .40
» CEF speed contest Design Discussions
» Cox Conquest, mods and experiences.
» Cox Conquest "RJL"
» [Want to Buy] Cox Conquest .15
Page 2 of 3
