» Help Pee Wee tank cap .020by rdw777 Today at 1:30 pm
by GallopingGhostler Today at 11:34 am
by rdw777 Today at 10:32 am
by rdw777 Today at 9:17 am
by getback Today at 8:21 am
by getback Today at 6:31 am
by roddie Yesterday at 10:50 pm
by F4D Phantom II Yesterday at 9:33 pm
by rsv1cox Yesterday at 7:29 am
» Post your Older books
by rsv1cox Mon May 06, 2024 7:51 pm
by rsv1cox Mon May 06, 2024 6:58 pm
» I brake for Turtles....
by rsv1cox Mon May 06, 2024 6:38 pm
What is a thin cylinder wall?
Matt1967- Moderate Poster
Re: What is a thin cylinder wall?
Hi Matt, didn't see you sneak in.
Welcome to the forum.
Lots of cylinder info here.
https://www.coxengineforum.com/h23-cylinder-identification
Scroll down, last photo on the right is a "thin wall".
Bob(dckrsn)
Bob(dckrsn)
dckrsn- Diamond Member
dckrsn wrote:Hi Matt, didn't see you sneak in.
Bob(dckrsn)
Bob you are good man, thanks for the reply....I'm looking at the chart but I am not seeing thin walled....did I miss it?
Thinner style cylinders can be found on engines made before the 1970s. They can run much cooler due to their thin walls. But can be damaged more easily when removing/replacing or in a crash.
I JUST SAW THIS. I am looking at a tatone muffler that is for a thin walled. Should I assume that muffler will only fit pre 1970's ?
Thin wall vs. standard thicker cylinder. Left cylinder is off a 1978 Babe Bee and the one on the right (the thin one) is off a 1962 Babe Bee. The reason there are thin, stepped and thick cylinders mostly comes down to the honing machines at the factory. Their older machines required the lip on the base of the cylinder to hold it in the machine. In 1972, Cox had a new honing machine made that didn't require the lip at the base. When they came out with exhaust throttles in 1969, the throttle needed the cylinder to be thicker to support it yet the honing machine still required a the lip so they came up with the stepped cylinders. With the new honing machine in use, they could save money and skip a step in the cylinder making process so by the mid 70s, all .049 and .051 cylinders were of the thick type.
Wow OK a significant amount of knowledge. Thank you. Matt
» Cox thin-wall .049 Cylinder...
» Wanted: unstamped thin wall #1 cylinder
» Po'boy's exhaust throttle for thin wall cylinder
» Thin Wall Cylinders
