» Happy Anzac Day!by GallopingGhostler Today at 11:44 am
» Fox .35 Modifications
by GallopingGhostler Today at 11:37 am
by rsv1cox Today at 6:17 am
by getback Today at 5:20 am
by getback Today at 5:17 am
by Levent Suberk Yesterday at 11:23 pm
by roddie Yesterday at 9:25 pm
by rdw777 Yesterday at 7:15 pm
by rdw777 Yesterday at 7:06 pm
by roddie Yesterday at 2:39 pm
by batjac Wed Apr 24, 2024 9:33 pm
1995 Puma Typhoon 2.5cc
These engines were originally imported into the USA from Russia by Hobbyclub.
This is definitely not a use out of the box engine. The crankcase needed swarf flushing out of it and there were burrs on the cylinder liner.
Still to be fixed - the propeller driver stands off too far from the crankcase exposing the open ball bearings (it is a weepy) rather than shrouding them in. Need to examine this one carefully as the propeller driver isn't thick enough for a simple ream.
Re: 1995 Puma Typhoon 2.5cc
Ian I used these for practice combat. Very crude engines, ( Fox .35's of combat engines). But, they deliver moderate power. Nothing like a modern F2D engine. With the correct prop, I use the Russian glass props, they can turn up into the 27-28K range. I can get it to turn more but it's just not useable power. I made a Nelson head for mine. ABC construction which is somewhat like dinosaur in combat due to weight. I picked up two for $30 at a swap meet. It has a nasty attitude initially until broken in. It cost more in plugs than the trouble it was worth to do so. This was very frustrating to break in. I had to add a lot of head shims and a lot of bench running which shouldn't be necessary for a combat engine but it was worth it. It now readily starts and is reliable. Unfortunately, it's real loud. I can only fly this engine at our sister field alongside of a airport due to the noise. I only run this on 10A% nitro. The rear exhaust is a pain in the rear. It can and will melt foamie wings even though the exhaust is directed in a Y. When you go to adjust the needle, the exhaust burns the hell out of your thumb. My findings were the same as yours internally. I chamfered many parts and cleaned up a lot inside. Ken
Thanks Ken,
Quite a few Eastern European/Russian engines have come my way recently and it is difficult to find any detail of information on them. What I can tell you is that this was originally sourced in the USA and had an original price tag of $64. For 1995, this was expensive.
It arrived to me with a replacement glow insert but, as usual, I have put it in a safe place and can't find it!
This one definitely needs more work before I attempt to run it but I do like the look of it!
» Enya 60 Typhoon
» Guillow's Typhoon 900 series
» Almost "NEW" Enya .29-III Super Typhoon purchase (last week)
» COX R/C E-Z Bee...
